[fusion-trac] #176: Legend widget misbehaves when you set
maxscaledenom to a layer that is outside the web min / maxscale
Fusion
trac_fusion at osgeo.org
Thu Feb 5 10:01:47 EST 2009
#176: Legend widget misbehaves when you set maxscaledenom to a layer that is
Reporter: pdeschamps | Owner: pdeschamps
Type: defect | Status: closed
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.1.0
Severity: Minor | Resolution: fixed
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by pdeschamps):
* status: new => closed
* resolution: => fixed
Comment:
added login in the scale processing to reset the layers min / max scales
to be set to the main map's min man scales if they happen to exceede the
main map scales. without this you get un expected ui behaviour in the
legend.
/fusion/trunk/layers/MapServer/php/LoadMap.php REV # 1776
I added closes comment in the commit however it did not close the bug
Ticket URL: <http://trac.osgeo.org/fusion/ticket/176#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
