[fusion-trac] #192: Legend becomes garbled when expanded/collapsed
Fusion trac_fusion at osgeo.org
Thu Feb 5 15:23:28 EST 2009
 Reporter:  chrisclaydon        |         Owner:  madair
     Type:  defect              |        Status:  reopened
 Priority:  P1                  |     Milestone:  2.0
Component:  Widgets             |       Version:  SVN
 Severity:  Major               |    Resolution:
 Keywords:                      |   External_id:  1176823
    State:  Analysis Requested  |       Browser:  IE7
       Os:  All                 |
Comment (by madair):
 I'm having trouble reproducing this consistently now, however i did see it
 occur once.    A solution that I would like to see tested in your
 environment is to add "overflow:hidden" to the ".jxTree li,.jxTreeRoot li"
 selector in the template CSS.  I added that to slate/jxtheme.css and
 haven't seen the problem since in that template and that solution also
 solved a very similar issue in another project.  If this solves the
 problem, the fix would have to go into the CSS for the templates.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/192#comment:7>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
