[fusion-trac] #214: Map Does not load when SingleTile = False
Fusion trac_fusion at osgeo.org
Mon Feb 23 13:33:25 EST 2009
 Reporter:  bberdel  |         Owner:  madair
     Type:  defect   |        Status:  assigned
 Priority:  P1       |     Milestone:  2.0
Component:  Core     |       Version:  2.0 - beta
 Severity:  Major    |    Resolution:
 Keywords:           |   External_id:
    State:  New      |       Browser:  All
       Os:  All      |
Changes (by madair):
  * status:  new => assigned
Comment:
 is this with the Sheboygan samples?  Note that setting singleTile to
 true/false depends on the MapDefinition for the map, i.e. for a given
 MapDef the setting should be either true or false but not both.
 If you aren't testing with
 Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition can you post
 the MapDefinition here please?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/214#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
