[fusion-trac] #201: Can't switch themes when using theme param in URL
Fusion trac_fusion at osgeo.org
Thu Jan 22 15:57:10 EST 2009
   Reporter:  madair  |       Owner:  madair
       Type:  defect  |      Status:  new
   Priority:  P2      |   Milestone:  1.1
  Component:  Core    |     Version:  1.1.0
   Severity:  Minor   |    Keywords:
External_id:          |       State:  New
    Browser:  All     |          Os:  All
 The Map menu widget calls LoadMap with a new mapTag but that never gets
 used since loadMap checks the value in Fusion.queryParams and uses that if
 it is available.
 Proposed solution is to clear the queryParam after it has been used in the
 initial page load.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/201>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
