[fusion-trac] #203: Remove default settings from widget info for
multipurpose widgets
Fusion
trac_fusion at osgeo.org
Wed Jan 28 11:15:24 EST 2009
#203: Remove default settings from widget info for multipurpose widgets
Reporter: chrisclaydon | Owner: chrisclaydon
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Minor | Keywords:
External_id: 1190167 | State: Approved
Browser: All | Os: All
Some widgets have settings that change their behaviour in such a way that
any default icons or strings are not applicable. Examples are
!ExtentHistory and !ZoomOnClick, which require different icons, tooltips,
labels etc. depending on whether their direction settings.
At some point, I'd like to update the widget info format to allow multiple
default settings for different parameter values. But in the meantime, I'm
just going to remove the default settings.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/203>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
