[fusion-trac] #204: Add setting to Select widget to allow
single-point click to select only the topmost feature
Fusion
trac_fusion at osgeo.org
Wed Jan 28 14:12:52 EST 2009
#204: Add setting to Select widget to allow single-point click to select only the
topmost feature
Reporter: chrisclaydon | Owner: chrisclaydon
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Minor | Keywords:
External_id: 1194566 | State: Approved
Browser: All | Os: All
The Select widget currently performs deep selection even when the user
clicks on a single point (as opposed to dragging a rectangle). Users have
requested that a single click only return the topmost feature, as is
common in other applications.
A new parameter, !PointClickSingleSelect, will be added to the Select
widget to allow the behaviour to be controlled. If set to true, only the
topmost feature will be selected. If set to false, any features below the
clicked point will be selected, up to the value of the !MaxFeatures
setting.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/204>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
