[fusion-trac] #266: Maptips Should Only Show for Visible Layers
Fusion
trac_fusion at osgeo.org
Thu Jul 2 17:07:29 EDT 2009
Reporter: tnolte | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0 - beta
Severity: Major | Resolution:
Keywords: maptips | External_id:
State: New | Browser: All
Os: All |
Comment (by pagameba):
The visibility of layers is controlled on the client side and included in
a call to mapserv to request specific layers to be drawn. Same with
extent and image size. This means that the map is (almost) never updated
to reflect the transient client side changes.
I think we should modify the Maptips request in
Layers/MapServer/MapServer.js to pass the current extent and visible
layers along with the other parameters around line 807, then modify the
MapTips.php to use this to correctly set up the map object.
Does this sound like a reasonable approach?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/266#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
