[fusion-trac] #59: Tiled map ScaleZoom Problems
Fusion
trac_fusion at osgeo.org
Thu Jul 23 11:23:13 EDT 2009
Reporter: zspitzer | Owner: madair
Type: defect | Status: closed
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.1 RC1
Severity: Major | Resolution: fixed
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by pagameba):
* status: new => closed
* resolution: => fixed
Comment:
Zac, I just tested this with Fusion trunk and it seems to be doing more
reasonable things now. I did make some changes to the Navigator widget
related to tiled maps (setting it to work on fixed resolutions coming from
OpenLayers rather than a continuous range of values) and I think this may
have fixed the issue or at least made it work more reasonably. I'm going
to close the ticket but if you test with your template/map definitions and
find it is not, please reopen.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/59#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
