[fusion-trac] #220: Selection hides other features in IE6
Fusion
trac_fusion at osgeo.org
Mon Mar 2 11:36:56 EST 2009
Reporter: chrisclaydon | Owner: madair
Type: defect | Status: assigned
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution:
Keywords: | External_id: 1193382.01
State: Analysis Requested | Browser: IE6
Os: All |
Comment (by chrisclaydon):
Using the Fusion code from the fusion2-mg21 branch, I loaded up the slate
template, zoomed into the Sheboygan Parcels layer, and selected a parcel.
The selection overlay showed up with an opaque background that hid all the
map data underneath. I tested with a real version of IE6
(6.0.2900.2180.xpsp_sp2_rtm.040803-2158) in a VM. It could be that
IETester does not emulate the PNG transparency issues present in IE6.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/220#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
