[fusion-trac] #223: All instances of widget should not
necessarily be activated together
Fusion
trac_fusion at osgeo.org
Wed Mar 11 16:11:44 EDT 2009
#223: All instances of widget should not necessarily be activated together
Reporter: pagameba | Owner: madair
Type: defect | Status: closed
Priority: P1 | Milestone: 2.0
Component: Widgets | Version: 2.0 - beta
Severity: Critical | Resolution: fixed
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by pagameba):
* status: new => closed
* resolution: => fixed
Comment:
(In [1814]) closes #223. Modify widget activation to only activate other
widgets if they should be activated and provide a hook for individual
widgets to determine whether they should be activated or not. Modified
Zoom and Select to use this new feature. Other widgets that have problems
should be reported as separate tickets.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/223#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
