[fusion-trac] #229: MapGuide FeatureReaders not being closed properly?
Fusion
trac_fusion at osgeo.org
Mon Mar 23 17:03:46 EDT 2009
Reporter: jbirch | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.1.1
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
There are a few cases where I believe an !MgFeature is being opened and
not being closed properly.
1) I believe that for:
trunk/layers/MapGuide/php/Query.php
There is an !MgFeatureReader being opened on line 199 which is being
closed on line 268.
However, on line 261, I believe that a second !MgFeatureReader is being
opened using the same variable name without closing the initial
!MgFeatureReader first, and that this second reader is never closed.
2) It looks to me that in the file
trunk/widgets/Search/Search.php
The !MgFeatureReader called $features is only closed in the exception
handling logic, not in the normal code stream.
3) In:
trunk/widgets/SelectWithin/SelectWithin.php
On line 109, it appears that an !MgFeatureReader called $featureReader is
opened but not closed.
I believe that these may be the (partial?) cause of a problem I am having
with running out of connections.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/229>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
