[fusion-trac] #232: Maptip, Internet Explorer and AJAX issues
Fusion
trac_fusion at osgeo.org
Fri Mar 27 15:41:03 EDT 2009
Reporter: amorsell | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
I believe this still occurs with all releases of Fusion with MapGuide Open
Source. When displaying a maptip in IE7, the AJAX post-back occurs over
and over. This results in all spaces in the maptip text appearing as line
breaks and the maptip flashing as the AJAX call is made. This can be
easily seen at http://mapguide.spatialgis.com/mapguide/spokanemaps/. Zoom
in until parcels are available and then view the maptip and see the
oddities. Using Fiddler2 confirms the repetitive call backs.
There was a similar issue with the AJAX viewer at one point which was
solved by http://trac.osgeo.org/mapguide/ticket/17. I suspect the issue
with Fusion is similar.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/232>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
