[fusion-trac] #234: Mapguide utility function cause LoadMap to fail
Fusion
trac_fusion at osgeo.org
Tue Mar 31 11:48:39 EDT 2009
Reporter: beginbenoit | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: MapGuide | Version: 2.0 - beta
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
In fusion\layers\MapGuide\php\Utility.php, the function ByteReaderToString
will cause LoadMap.php calls to unexpectedly terminate during the building
of the JSON. The code in its current state likely uses the maximum amount
of memory available for the process to run and PHP throws an exception
that I was unfortunately unable to trap. The function should be changed to
use the built-in ToString function of the MgByteReader.
function ByteReaderToString($byteReader)
return $byteReader->ToString();
It would be possible to add some validation to prevent any issues, such as
calling GetMimeType to validate that the ToString will return something
that is the actual textual representation of the content held in it.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/234>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
