[fusion-trac] #236: Search.php errors
Fusion
trac_fusion at osgeo.org
Tue Mar 31 13:54:50 EDT 2009
Reporter: amorsell | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
This appears to still be present in 2.0b as well as older releases. If
the search widget encounters what it thinks is a null value, it will crash
with an error like:
"Value for PARCEL_NUM property is null. Exception occurred in method
MgProxyFeatureReader.GetProperty at line 448 in file
d:\build\mapguide_open_source_v2.0\build_30.11\mgdev\common\mapguidecommon\Services/ProxyFeatureReader.cpp"
To prevent this error, a change in search.php similar to
http://trac.osgeo.org/mapguide/changeset/3318 needs to occur.
Specifically, the Switch statement around line 170 needs to be wrapped in
an if statment with the changed code being:
if (!$features->IsNull($propName))
switch($propType)
case MgPropertyType::Boolean:
$val =
$features->GetBoolean($propName)? "true": "false";
break;
case MgPropertyType::Single:
$val =
$features->GetSingle($propName);
break;
case MgPropertyType::Double:
$val =
$features->GetDouble($propName);
break;
case MgPropertyType::Int16:
$val = $features->GetInt16($propName);
break;
case MgPropertyType::Int32:
$val = $features->GetInt32($propName);
break;
case MgPropertyType::Int64:
$val = $features->GetInt64($propName);
break;
case MgPropertyType::String:
$val =
$features->GetString($propName);
break;
Ticket URL: <http://trac.osgeo.org/fusion/ticket/236>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
