[fusion-trac] #237: Search.php results showing improper nulls
Fusion
trac_fusion at osgeo.org
Tue Mar 31 14:23:39 EDT 2009
Reporter: amorsell | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
The search widget is returning null values for valid fields in some
instances. The best way to see this is to load the package that can be
found here:
ftp://mapguide.spatialgis.com/Search_widget_issue.mgp
The isNull fix needs to be in place from ticket 236 before effectively
trying this scenario (you can also use this package to see that error
before implementing it). Open the flexible layout in a browser. Go to
Search by Owner under Parcel Search. Search by a last name of "Jones".
Notice that the second result of JONES, EILEEN shows no parcel ID value.
Click on the result to zoom to it. Notice in the property pane that there
is indeed a valid parcel ID. Now, use that parcel ID of 39101.9035 in the
Search by Parcel ID search instead. It will report that there are no
matches.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/237>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
