[fusion-trac] #253: Maptip opened URL does not obey sWinFeatures
Fusion
trac_fusion at osgeo.org
Mon May 4 12:57:53 EDT 2009
Reporter: amorsell | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.1.1
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
While trying to fix the default behavior of the maptip URL opened window
not having scrollbars, I discovered that the openLink function does not
obey the sWinFeatures.
Try editing the sWinFeatures on or around line 59 to something like:
sWinFeatures :
'menubar=no,location=no,resizable=yes,status=no,scrollbars=yes,width=1024,height=800',
But, the opened window will not reflect those overrides. The only way to
override the opened window behavior is through something like:
openLink : function(evt, url) {
//below line added since window.open did not seem to obey changes
in sWinFeatures
var myWinFeatures =
'menubar=no,location=no,resizable=no,status=no,width=1024,height=800,scrollbars=yes';
var taskPaneTarget = Fusion.getWidgetById(this.sTarget);
if ( taskPaneTarget ) {
taskPaneTarget.setContent(url);
} else {
var pageElement = $(this.sTarget);
if ( pageElement ) {
pageElement.src = url;
} else {
window.open(url, this.sTarget,
myWinFeatures);
OpenLayers.Event.stop(evt, true);
return false;
Ticket URL: <http://trac.osgeo.org/fusion/ticket/253>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
