[fusion-trac] #312: decode xml string before rendering attribute in
www\fusion\widgets\SelectionPanel.js
Fusion
trac_fusion at osgeo.org
Tue Nov 3 13:41:00 EST 2009
Reporter: poulet1212 | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
SelectionPanel?.js (Version is 2.1 beta): in the renderFeature function,
at line 403, the instruction:
td.innerHTML = layerObj.getElementValue(featureIdx, i);
outputs the requested attribute values for a selection.
If a value contains html tags such as links, it won't be rendered as html
but as simple text because the html tags are not decoded from the xml
string. for example a "<" should be decoded as "<" before it is passed
to innerHTML.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/312>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
