[fusion-trac] #315: Exception when using MapMenu widget with commercial layers
Fusion trac_fusion at osgeo.org
Fri Nov 6 03:45:43 EST 2009
 Reporter:  liuar    |         Owner:  zjames
     Type:  defect   |        Status:  new
 Priority:  P2       |     Milestone:  Future
Component:  Widgets  |       Version:  1.1.1
 Severity:  Major    |    Resolution:
 Keywords:           |   External_id:  1273030
    State:  New      |       Browser:  All
       Os:  All      |
Comment (by liuar):
 Hi Zak and other experts,
 I think this defect is caused by the project transform(coordinate system
 transform) from EPSG:900913(used by commercial layers) to other(EPSG:4326
 which is the default CS in openlayers) failed.
 Those transform failed occurred at line 18323 and 18406 in OpenLayers.js.
 Do you have any suggestions on this?
 BTW, it seems the projection for overview map is not changed per the
 MapMenu, is it a defect?
 Thanks,[[BR]]
 Arthur
Ticket URL: <http://trac.osgeo.org/fusion/ticket/315#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
