[fusion-trac] #324: Theme widget doesn't work because layer definition schema definition
Fusion trac_fusion at osgeo.org
Thu Nov 12 03:53:02 EST 2009
   Reporter:  christinebao  |       Owner:  Christine Bao
       Type:  defect        |      Status:  new
   Priority:  P2            |   Milestone:  Future
  Component:  Widgets       |     Version:  1.1.1
   Severity:  Major         |    Keywords:  Theme
External_id:  1276805       |       State:  New
    Browser:  All           |          Os:  All
 Steps to reproduce:[[BR]]
 Scenario 1:[[BR]]
 1. Load the attached bayarea_cities.sdf, let's name the layer as
 layer1.LayerDefinition.[[BR]]
 2. Create a map based on layer1.LayerDefinition using default setting, and
 create a flexible web layout based on the map using default setting. Let's
 name the web as web1.ApplicationDefinition.[[BR]]
 3. Open web1 in browser, choose Theme widget, using the default setting,
 and Apply. [[BR]]
 Result: Nothing happens. The map is not themed.
 Scenario 2:[[BR]]
 layer2.LayerDefinition. Make some change in layer2.LayerDefinition, for
 example, choose "OBJECTID" as Tooltips displayed for feature.[[BR]]
 2. Create a map based on layer2.LayerDefinition using default setting, and
 name the web as web2.ApplicationDefinition.[[BR]]
 3. Open web2 in browser, choose Theme widget, using the default setting,
 and Apply. [[BR]]
 Result: The map is themed.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/324>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
