[fusion-trac] #253: Maptip opened URL does not obey sWinFeatures
Fusion
trac_fusion at osgeo.org
Fri Oct 2 14:57:15 EDT 2009
Reporter: amorsell | Owner: madair
Type: defect | Status: closed
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution: invalid
Keywords: | External_id:
State: New | Browser: All
Os: All |
Changes (by madair):
* status: new => closed
* resolution: => invalid
Comment:
I'm not able to reproduce this in the Fusion 2.0 branch and the window
open code is getting the correct sWinFeatures value.
Looking at the spokanemaps example however, I can see that the
sWinFeatures value is being overridden by a value specified in the AppDef
file which is why you aren't getting the value you are expecting. You can
set the value for sWinFeatures for the MapTip in Studio.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/253#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
