[fusion-trac] #262: Measure Tool Does not work correctly
Fusion
trac_fusion at osgeo.org
Wed Oct 14 11:21:44 EDT 2009
Reporter: bberdel | Owner: madair
Type: defect | Status: closed
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: SVN
Severity: Major | Resolution: duplicate
Keywords: | External_id:
State: New | Browser: IE7
Os: All |
Changes (by madair):
* status: new => closed
* resolution: => duplicate
Comment:
Testing this with the current trunk implementation isn't showing any
errors and had the same behaviour as #247. I suspect the map was in a
projection other than lat/lon
and the issue is fixed now.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/262#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
