[fusion-trac] #287: Fail to narrow Task pane when drag the Vertical
Line
Fusion
trac_fusion at osgeo.org
Wed Sep 16 00:09:41 EDT 2009
#287: Fail to narrow Task pane when drag the Vertical Line
Reporter: jennyhe | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Keywords:
External_id: 1254170 | State: New
Browser: All | Os: All
From Autodesk QA
Steps:
1. Open the Fusion web layout.
2. Redline->Double Click Task Pane in the left panel.
3. Drag the Vertical line to resize the Task Pane
Results:
Please refer to the attached png file. If users drag the Vertical Line in
the position above the Red line in png file, Task pane could be narrowed.
However, if below the red line, it failed.
Expected results:
No matter where Users drag, it should work correctly.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/287>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
