[fusion-trac] #138: Search widget take wrong localization file
Fusion
trac_fusion at osgeo.org
Thu Sep 24 16:36:49 EDT 2009
Reporter: poulet1212 | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.0.7
Severity: Minor | Resolution:
Keywords: localize search widget | External_id:
State: New | Browser: All
Os: All |
Comment (by pagameba):
moved string files around to match MapGuide API and updated the various
spots in fusion.js and MapGuide/php/Common.php that are affected. Need
Mike to test and also check the build configuration file to make sure it
is including the json string files correctly from the new location.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/138#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
