[fusion-trac] #384: Buffer on the map with consume maps caused
the map Zoom To Extents
Fusion
trac_fusion at osgeo.org
Tue Apr 6 15:21:35 EDT 2010
#384: Buffer on the map with consume maps caused the map Zoom To Extents
Reporter: liuar | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1312969
State: New | Browser: All
Os: All |
Comment (by chrisclaydon):
The attached patch resolves the issue by adding a reloadNamedMap method to
Map.js, allowing the buffer function to reload only the MapGuide layer,
rather than reloading the consumer mapping layer as well.
The patch does not address the issue that the reloadMap method in
Generic.js (as used by consumer maps) causes the map to revert to its
initial extents. Although that is also reasonably easy to address, it's a
separate problem.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/384#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
