[fusion-trac] #315: Exception when using MapMenu widget with
commercial layers
Fusion
trac_fusion at osgeo.org
Wed Feb 10 15:27:29 EST 2010
#315: Exception when using MapMenu widget with commercial layers
Reporter: liuar | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1273030
State: New | Browser: All
Os: All |
Changes (by madair):
* owner: zjames => madair
Comment:
I can get most of this fixed but it seems that commercial layers can't be
used in the OverviewMap widget in OpenLayers (see http://n2.nabble.com/
Overview-Map-Question-td1822998.html#a1823001). I have spent a few hours
looking into the issue but I don't have a fix or even know why that is at
this point.
This imposes a few restrictions on the OverviewMap widget when it is used
in Fusion, ie. it can only be used with MapGuide, MapServer and WMS layer
types, and if a MapGroup ID is not specified in the widget extension, it
simply re-uses the main map baselayer. What should happen when the user
switches to a commercial layer from the MapMenu in this case?
Ticket URL: <http://trac.osgeo.org/fusion/ticket/315#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
