[fusion-trac] #141: Legend widget is not updating correctly
Fusion
trac_fusion at osgeo.org
Mon Feb 22 15:18:14 EST 2010
Reporter: CivilEng | Owner: madair
Type: defect | Status: closed
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.0.6
Severity: Critical | Resolution: fixed
Keywords: | External_id:
State: New | Browser: All
Os: Windows |
Changes (by madair):
* status: assigned => closed
* resolution: => fixed
Comment:
from the comments, it appears that the original issue has been solved so
closing this ticket.
I suspect the Fusion error mentioned in the above comment has been fixed
as there has been some fixes applied for commercial map layers as part of
other tickets.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/141#comment:6>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
