[fusion-trac] #351: Print widget doesn't work with IIS7
Fusion trac_fusion at osgeo.org
Tue Jan 5 01:32:40 EST 2010
 Reporter:  hubu          |         Owner:  hubu
     Type:  defect        |        Status:  new
 Priority:  P2            |     Milestone:  Future
Component:  Widgets       |       Version:  1.1.1
 Severity:  Major         |    Resolution:
 Keywords:  Print widget  |   External_id:  1282386
    State:  New           |       Browser:  All
       Os:  All           |
Comment (by hubu):
 I attached new patch to fix fusion issue. The previous patch caused the
 fusion break. Because there are some errors in the en.json. In the
 en.json, we are not allowed adding any comments, and each string should be
 separated by comma.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/351#comment:7>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
