[fusion-trac] #369: Buffer: Cancel buffer without object selected invokes a script error.
Fusion trac_fusion at osgeo.org
Wed Mar 10 04:34:43 EST 2010
 Reporter:  liuar    |         Owner:  madair
     Type:  defect   |        Status:  new
 Priority:  P2       |     Milestone:  2.0
Component:  Widgets  |       Version:  2.0 - beta
 Severity:  Major    |    Resolution:
 Keywords:           |   External_id:  1308351
    State:  New      |       Browser:  All
       Os:  All      |
Comment (by liuar):
 mapName is a local variable defined in function FillLayerList(). If
 there's no object selected, there will be a error like mapName is
 undefined in
 function OnCancel()
     var map = GetParent().Fusion.getMapByName(mapName);
     map.clearSelection();
     //mf.GotoHomePage();
 so, the solution is make the mapName a global variable and check the value
 of mapName before getting the map.[[BR]]
 function OnCancel()
     if(mapName == "undefined")
         return;
Ticket URL: <http://trac.osgeo.org/fusion/ticket/369#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
