[fusion-trac] #315: Exception when using MapMenu widget with
commercial layers
Fusion
trac_fusion at osgeo.org
Mon Mar 15 15:53:54 EDT 2010
#315: Exception when using MapMenu widget with commercial layers
Reporter: liuar | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: 2.0
Component: Widgets | Version: 1.1.1
Severity: Major | Resolution:
Keywords: | External_id: 1273030
State: New | Browser: All
Os: All |
Changes (by madair):
* status: new => assigned
Comment:
at rev 2098 - use consistent handling of projection and units - set a
reasonable default value in AppDef.js when parsing the AppDef, but values
may be overridden by LoadMap response. Let OL handle setting up it's
units/projection via addLayer().
If there are any commercial layers included in the MapGroup,
sphericalMercator will be set to true and the projection will be EPSG:3785
Ticket URL: <http://trac.osgeo.org/fusion/ticket/315#comment:8>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
