[fusion-trac] #373: Overview-Wrong Coord Sys
Fusion trac_fusion at osgeo.org
Thu Mar 18 12:32:50 EDT 2010
   Reporter:  markpendergraft  |       Owner:  madair
       Type:  defect           |      Status:  new
   Priority:  P2               |   Milestone:  2.0
  Component:  Widgets          |     Version:  SVN
   Severity:  Minor            |    Keywords:  overview,projection
External_id:                   |       State:  New
    Browser:  All              |          Os:  All
 When a map's projection is defined using ProjectionDef and ProjectionCode
 in the ApplicationDefiniition, the Overview Map does not display/work
 properly.  The overview retains the default projection of LL84 and does
 not use the maps defined projection.
 The current workaround involves editing the loadOverview() function in the
 Overview.js widget to include the following lines:
 this.mapObject.projection = this.getMap().oMapOL.getProjection();
 this.mapObject.oLayerOL.projection = this.getMap().oMapOL.getProjection();
Ticket URL: <http://trac.osgeo.org/fusion/ticket/373>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
