[fusion-trac] #376: Fusion Legend Issues
Fusion trac_fusion at osgeo.org
Fri Mar 26 09:18:16 EDT 2010
 Reporter:  bberdel  |         Owner:  madair
     Type:  defect   |        Status:  new
 Priority:  P2       |     Milestone:  2.0
Component:  Widgets  |       Version:  2.0.0-RC1
 Severity:  Major    |    Resolution:
 Keywords:           |   External_id:
    State:  New      |       Browser:  All
       Os:  All      |
Changes (by bberdel):
  * milestone:  Future => 2.0
Comment:
 I have confirmed that the issue with selecting the root map, and it not
 turning the map back on after has it been turned off Still exists with the
 Standard template / Appdef / Sheboygan dataset.  So that does not appear
 to be package dependent:
 Line: 1038  mapguide.js
 Error: 'this.oLayerOL2' is null or not an object
 However the other error does not occur on the tiled Sheboygan example, but
 that is also not a raster dataset.  I am using a MrSID dataset…
 'LegendLabel' is null or not an object in legend.js (Line 9 in
 createTreeItem) and the variable style is coming in as null.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/376#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
