[fusion-trac] #404: New Commercial Map Service Layer support -
Open Street Map
Fusion
trac_fusion at osgeo.org
Tue Sep 7 15:54:26 EDT 2010
#404: New Commercial Map Service Layer support - Open Street Map
Reporter: liuar | Owner: liuar
Type: enhancement | Status: new
Priority: P2 | Milestone: 2.2
Component: Core | Version: 1.1.1
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Changes (by madair):
* milestone: Future => 2.2
Comment:
without having tested this, the patch looks ok to me. Some comments
though:
- you should be using curly brackets for your if/else statements in
BasemapSwitcher.js
- you can add the files required in the Fusion build of OpenLayers in the
file fusion.cfg and remove the section of code in fusion.js that loads the
extra OL file. part of the 2.2 release will be an update of OpenLayers to
2.10
I have changed the milestone to 2.2
Ticket URL: <http://trac.osgeo.org/fusion/ticket/404#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
