[fusion-trac] #137: Support multiple hosts for tile maps
Fusion
trac_fusion at osgeo.org
Thu Sep 9 16:33:22 EDT 2010
Reporter: jbirch | Owner: madair
Type: enhancement | Status: assigned
Priority: P2 | Milestone: 2.3
Component: Widgets | Version: SVN
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Changes (by madair):
* milestone: 2.2 => 2.3
Comment:
it appears that this is already supported in Fusion/OpenLayers, but only
for static tilecache as opposed to retrieving tiles from the MapGuide
server.
The way to configure it is:
1. in config.json, set the mapguide/tileCacheUrl with an array of strings,
which are the hosts that are serving up the tiles, e.g.:
"tileCacheUrl":
["http://host01/sheboygan","http://host02/sheboygan","http://host03/sheboygan"]
2. use the OL MapGuide layer useHttpTile option. Set this in the <Map>
element extension like so:
<Map xsi:type="MapGuideLayerType">
<Type>MapGuide</Type>
<SingleTile>false</SingleTile>
<Extension>
<ResourceId>Library://Samples/Sheboygan/MapsTiled/Sheboygan.MapDefinition</ResourceId>
<Options>
<useHttpTile>true</useHttpTile>
</Options>
</Extension>
</Map>
And you should get your tiles pulled randomly from all the servers in the
array. I don't have a setup to fully test this but in Firebug I can see
that tiles are being requested from the 3 servers (with 404 responses
since I don't actually have anything at those URLs).
Supporting this mechanism with tiles served from the MapGuide server would
require some coding changes but is viable. Is that something that should
be done? I suspect most production sites would build a pre-seeded tile
cache.
In any case, bumping this to 2.3 since it already works for the most part
or close the ticket if the above is sufficient.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/137#comment:3>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
