[fusion-trac] #408: IE9-beta createElement fix
Fusion
trac_fusion at osgeo.org
Wed Sep 29 09:22:51 EDT 2010
Reporter: madair | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: 2.2
Component: Widgets | Version: 2.0 - beta
Severity: Minor | Keywords:
External_id: | State: New
Browser: Other | Os: All
This patch to be applied to the 2.2 branch, 2.3 will have the fix from
Mootools.
from Ted Yang:
I’m working on IE9 support from Autodesk, and I found one defect in JxLib,
this is because IE9 beta works different with IE8.
var a = document.createElement("<div>");
this code works on IE8, but not works on IE9 beta;(Note that if the web
page is quite simple, the IE9 will run the page on “Quirks mode” and this
code will work, but in most standard webpage this code doesn’t work)
var a = document.createElement("div");
this code works on IE9 beta, but not works on IE8;
so we suggest to fix it in JxLib’s code, and I wish someone can review it
and submit it before Oct. 1th.
Original code:
Document.implement({
newElement: function(tag, props) {
if (Browser.Engine.trident && props) {
['name', 'type', 'checked'].each(function(attribute) {
if (!props[attribute]) return;
tag += ' ' + attribute + '="' + props[attribute] +
if (attribute != 'checked') delete
props[attribute];
tag = '<' + tag + '>';
return $.element(this.createElement(tag)).set(props);
newTextNode: function(text) {
return this.createTextNode(text);
getDocument: function() {
return this;
getWindow: function() {
return this.window;
Fixed code(our solution, tested on IE9 beta):
document.newElement = function(tag, props) {
var createdElement;
if (attribute != 'checked') delete props[attribute];
var replaceTag = '<' + tag + '>';
try {
createdElement = this.createElement(replaceTag);
catch (e) {
createdElement = this.createElement(tag);
else {
return $.element(createdElement).set(props);
Ticket URL: <http://trac.osgeo.org/fusion/ticket/408>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
