[fusion-trac] #473: query() ignores the options.filter parameter
Fusion
trac_fusion at osgeo.org
Tue Aug 9 21:07:16 EDT 2011
Reporter: liuar | Owner: liuar
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: MapGuide | Version: 2.0
Severity: Major | Keywords:
External_id: 1344103.02 | State: New
Browser: All | Os: All
The query(options) seems to ignore the filter parameter. [[BR]]
[[BR]]
The following code selects all elements on the layers specified, but it
should only select one element based on the filter. No matter what I do
with the filter text nothing changes. [[BR]]
[[BR]]
var Map = cmsmapframe.Fusion.getWidgetById('Map');
var options = {};
//The filter seems to be broken - itis completely ignored and all features
onthe layers are selected
options.filter = "(ASSETNUMBER='" + assetnumber + "')";
//alert(options.filter);
//options.maxFeatures = 1; //this works
//Note: The filter causes an error if a geometry is not provided. These
numbers create a rectangle around the entire floorplan. (LL,UL,UR,LR)
options.geometry = 'POLYGON((-9086048 5086543,-9086048 5086649,-9085921
5086649,-9085921 5086543))';
options.layers = '1 Hr Fire Door Fail,1 Hr Fire Door Pass,1 Hr Fire Wall
Fail,1 Hr Fire Wall Pass,1 Hr Smoke Wall Fail,1 Hr Smoke Wall Pass,2 Hr
Fire Door Fail,2 Hr Fire Door Pass,2 Hr Fire Wall Fail,2 Hr Fire Wall
Pass';
Map.query(options);
In MapGuide.js, the options.filter parameter is not pass to MapGuide
var r = new Fusion.Lib.MGRequest.MGQueryMapFeatures(this.getSessionID(),
this._sMapname,
options.geometry,
maxFeatures,
persist,
options.selectionType || this.selectionType,
options.layers,
layerAttributeFilter);
Ticket URL: <http://trac.osgeo.org/fusion/ticket/473>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
