[fusion-trac] #486: Base map layers show in wrong places
working with Bing Maps
Fusion
trac_fusion at osgeo.org
Thu Dec 1 07:17:06 EST 2011
#486: Base map layers show in wrong places working with Bing Maps
Reporter: christinebao | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: 2.3
Component: MapGuide | Version: 2.0
Severity: Critical | Keywords:
External_id: 1432080 | State: New
Browser: All | Os: All
Comment(by jng):
Just to comment on this particular bit:
Replying to [comment:25 Christinebao]:
> The map set up by Studio uses Google layer scales. However not sure
about other maps which user may manually change the scale list.
> It was expected that the overlay can dynamically match to the base
layer, but it seems not work in this way. The overlay is hard coded to use
a scale at certain index.
> For now we need to fix this issue quickly. You can assume the scale list
is Google layers, and make sure all the commercial layers work.
The layer that's displaced is not the MG dynamic overlay, it's the MG
tiled layer(s)
If you look at a mixed tiled/dynamic map in the basic AJAX viewer the
dynamic overlay layers are constrained to the scales in the finite scale
list.
With fusion it's pretty much similar except that now MG tiled layers are
constrained to the scales of the Google Commercial scale list (being fixed
scales, these tiled layers must either be at the same scales as the Google
scale list or approximately close to it). The MG dynamic overlays will
still be constrained to whatever the MG tiled layers are constrained at.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:27>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
