[fusion-trac] #499: Solid color will not be remembered as
"background color" when opening again
Fusion
trac_fusion at osgeo.org
Fri Dec 2 01:16:36 EST 2011
#499: Solid color will not be remembered as "background color" when opening again
Reporter: liuar | Owner: liuar
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
steps:[[BR]]
1. In redline layer creation, click on "Background color", set it as a
not-transparency color.[[BR]]
2. Click "OK", you'll find the color has been set as "Background
color".[[BR]]
3. Open color select dialog again.[[BR]]
[[BR]]
Expect:[[BR]]
100% transparency is not checked as currently background color is not
transparency.[[BR]]
Actual:[[BR]]
it's checked which makes that directly OK clicking will change background
color to be transparency.[[BR]]
Ticket URL: <http://trac.osgeo.org/fusion/ticket/499>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
