[fusion-trac] #486: Base map layers show in wrong places
working with Bing Maps
Fusion
trac_fusion at osgeo.org
Fri Dec 2 02:54:15 EST 2011
#486: Base map layers show in wrong places working with Bing Maps
Reporter: christinebao | Owner: madair
Type: defect | Status: assigned
Priority: P2 | Milestone: 2.3
Component: MapGuide | Version: 2.0
Severity: Critical | Keywords:
External_id: 1432080 | State: New
Browser: All | Os: All
Comment(by Christinebao):
Hi Jng,
You patch changed 2 files, and I have integrated them into fusion, the
modified files are attached in Fix1.zip.
However it did not fix the problem. Bing map still offset, and other
commercial layers work. Same as before. Would you please check why?
Thanks & regards,
Christine
Ticket URL: <http://trac.osgeo.org/fusion/ticket/486#comment:28>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
