[fusion-trac] #432: Oracle 11gR2.0.2.0 Selection Issue
Fusion
trac_fusion at osgeo.org
Wed Jan 26 11:45:21 EST 2011
Reporter: mch | Owner: madair
Type: defect | Status: new
Priority: P1 | Milestone: Future
Component: MapGuide | Version: 2.0
Severity: Major | Keywords: Oracle, selection, clock-wise
External_id: | State: New
Browser: All | Os: Windows
Unpredictable results occur when selecting from the AJAX viewer using the
following methods:
1) Marquee Select.
2) Polygon Select where the polygon is drawn in a clockwise direction.
Oracle has confirmed this behaviour in this version of Oracle. The same
behaviour occurs when performing SDO_RELATE queries directly in Oracle
using a clockwise polygon.
Tests with Oracle 10g, 11gR1 and 11gR2.0.1 all work as expected.
Oracle has pointed at MapGuide as the problem as Oracle insists polygons
be defined in a counter-clockwise direction.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/432>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
