[fusion-trac] #475: SelectWithIn does't work while the map cs
doesn't consist with layer cs
Fusion
trac_fusion at osgeo.org
Tue Oct 11 22:11:51 EDT 2011
#475: SelectWithIn does't work while the map cs doesn't consist with layer cs
Reporter: liuar | Owner: liuar
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: 1406161 | State: New
Browser: All | Os: All
!SelectWithIn bases on the MapGuide API !QueryFeatures which accepts a
geometry parameter. The geometry represents a spatial filter to perform
the query whose coordinates should base on the Map CS. However, in
!SelectionWith.php, the coordinates are based on Layer CS, which causes
this defect.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/475>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
