[fusion-trac] #468: Use of tiled baselayers with commercial layers
Fusion
trac_fusion at osgeo.org
Fri Oct 21 15:33:27 EDT 2011
Reporter: liuar | Owner: madair
Type: defect | Status: assigned
Priority: P1 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Comment(by madair):
I was able to get this to work with the following steps:
- with Maestro, set up the tiled layer so that it has the same scale
levels (finite display scales) as the google layer, if you don't specify
the lowest scales, specify a zoomOffset in the layer options in AppDef.
e.g. using the set of scales:
1128.50004257674
2257.00008515349
4514.00017030697
9028.00034061395
18056.0006812279
36112.0013624558
72224.0027249116
144448.005449823
288896.010899646
577792.021799293
1155584.04359859
use a zoomOffset of 9
- with Maestro, set the coordinate system to spherical mercator:
PROJCS["WGS 84 / Pseudo-Mercator",GEOGCS["Popular Visualisation
CRS",DATUM["Popular_Visualisation_Datum",SPHEROID["Popular Visualisation
Sphere",6378137,0],TOWGS84[0,0,0,0,0,0,0]],PRIMEM["Greenwich",0],UNIT["degree",0.01745329251994328]],UNIT["m",1],PROJECTION["Mercator_1SP"],PARAMETER["central_meridian",0],PARAMETER["scale_factor",1],PARAMETER["false_easting",0],PARAMETER["false_northing",0],AXIS["X",EAST],AXIS["Y",NORTH]]
I had to do this in the XML editor because the WKT is not available in the
drop downs
- in Fusion Mapguide layer, don't set the DPI value to 96 but use the
OpenLayers default
- OpenLayers MapGuide layer is patched to support the zoomOffset property
Then using the following MapGroup in AppDef, we can get MapGuide tiled
layer overlaid on the Google layer:
<MapGroup id="ticket468">
<InitialView>
<MinX>-9774168</MinX>
<MinY>5415995</MinY>
<MaxX>-9754637</MaxX>
<MaxY>5434757</MaxY>
</InitialView>
<Map>
<Type>Google</Type>
<Extension>
<ResourceId>google</ResourceId>
<Options>
<name>GoogleLayer</name>
<type>G_PHYSICAL_MAP</type>
<isBaseLayer>true</isBaseLayer>
<sphericalMercator>true</sphericalMercator>
</Options>
</Extension>
</Map>
<Map id="mg1">
<Type>MapGuide</Type>
<SingleTile>false</SingleTile>
<Extension>
<ResourceId>Library://Samples/Sheboygan/MapsTiled/SheboyganSphericalMerc.MapDefinition</ResourceId>
<Options>
<isBaseLayer>false</isBaseLayer>
<useOverlay>true</useOverlay>
<zoomOffset>9</zoomOffset>
</Options>
</Extension>
</Map>
</MapGroup>
Ticket URL: <http://trac.osgeo.org/fusion/ticket/468#comment:2>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
