[fusion-trac] #527: Resize of map window with commercial layer in MapGuide breaks context menu
Fusion
trac_fusion at osgeo.org
Fri Jun 1 23:08:13 PDT 2012
Reporter: trevorwekel | Owner: trevorwekel
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: MapGuide | Version: SVN
Severity: Major | Keywords:
External_id: | State: New
Browser: Firefox 3 (beta) | Os: All
The IE9 Beta workaround submitted in Ticket #424 seems to have an
unexpected side effect with Firefox 9+. After a window resize, the resize
event in window.event is sent instead of the contextmenu event. This
effectively disables any context menu interaction after a window resize.
When the IE9 workaround is removed, Firefox behaves as expected and IE9
does not seem to require the patch any longer.
To test, apply the SheboyganBing.mgp to an existing Sheboygan install then
execute the right click context menu after a window resize.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/527>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
