[fusion-trac] #528: Feature Info widget defects
Fusion trac_fusion at osgeo.org
Mon Jun 25 21:01:37 PDT 2012
   Reporter:  jng      |       Owner:  jng
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 From Gordon:
 Modify the the featureinfo.php widget to only show layers that are both
 selectable and visible in the legend.
 if(($layer->IsVisible?()) && $layer->GetSelectable?()) {
 $layerName[$layer->GetName?()] = $layer->GetLegendLabel?(); }
 Around line 53 in /fusion/widgets/featureinfo/classes/featureinfo.php
 Ideally also, this list of layers should update itself as the map scale
 changes.
 Secondly, when display_errors = On in php.ini attempting to do a selection
 will fail because due to a PHP notice on the server side:
 PHP Notice:  Undefined variable: _SESSION in C:\Workspace\fusion-
 trunk\layers\MapGuide\php\Utilities.php on line 793
Ticket URL: <http://trac.osgeo.org/fusion/ticket/528>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
