[fusion-trac] #537: build files should be included in build output
Fusion
trac_fusion at osgeo.org
Sun Sep 2 20:39:52 PDT 2012
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: P2 | Milestone: Future
Component: Core | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
It is currently difficult to make customizations to a deployed copy of
Fusion (ie. Modify fusion.js or some widget and re-build a new compressed
version of fusionSF-compressed.js) because the build process does not
include the following:
* The build.xml
* The template config.json
* The utils folder required by build steps in build.xml
These files/directories should also be copied to the target output folder
as part of the normal build step in build.xml
Ticket URL: <http://trac.osgeo.org/fusion/ticket/537>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
