[fusion-trac] #539: Task Pane resident widgets when invoked should expand the task pane if currently collapsed
Fusion
trac_fusion at osgeo.org
Wed Sep 5 01:31:44 PDT 2012
currently collapsed
Reporter: jng | Owner: jng
Type: enhancement | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
Launch a Fusion layout using the Slate template (or any template with a
non-floating Task Pane). Collapse the task pane
Invoke any widget that would load content into the task pane. The
collapsed task pane does not re-expand. This is bad UX as from the user's
perspective it's as though nothing had happened.
If a new URL is loaded into the Task Pane (by a widget or
programmatically) it should expand itself if it is in a collapsed state.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/539>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
