[fusion-trac] #583: Prompt redline labels per redline drawn
Fusion trac_fusion at osgeo.org
Mon Jul 22 23:27:32 PDT 2013
   Reporter:  jng          |       Owner:  jng
       Type:  enhancement  |      Status:  new
   Priority:  P2           |   Milestone:  Future
  Component:  Widgets      |     Version:  2.0
   Severity:  Major        |    Keywords:
External_id:               |       State:  New
    Browser:  All          |          Os:  All
 Currently the redline widget has a boolean extension property that
 determines whether a drawn redline will prompt the user for a label.
 The problem is that this setting is global. The widget will either prompt
 the user for each redline drawn or not at all.
 Instead it is much simpler to add a checkbox in the Edit Redline UI that
 controls whether to prompt the user for a label on a drawn redline. If
 checked: prompt. If unchecked: do not prompt.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/583>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac mailing list
