[fusion-trac] #566: Redline doesn't work on exclusively tiled map
    Fusion
    trac_fusion at osgeo.org
    Thu May 23 21:18:09 PDT 2013
   Reporter:  jng      |       Owner:  madair
       Type:  defect   |      Status:  new
   Priority:  P2       |   Milestone:  Future
  Component:  Widgets  |     Version:  2.0
   Severity:  Major    |    Keywords:
External_id:           |       State:  New
    Browser:  All      |          Os:  All
 Redline geometry recorded by the Redline widget will fail to display on a
 map if the map is exclusively all tiled layers.
 The Fusion.Layer.MapGuide class needs some sort of logic that allows for
 dynamic OL layers to be attached at runtime instead of during the
 initialization phase.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/566>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
