[fusion-trac] #569: MapGuideViewerApi.js variable scope is not global
Fusion
trac_fusion at osgeo.org
Mon May 27 23:40:35 PDT 2013
Reporter: jng | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
External_id: | State: New
Browser: All | Os: All
The "global" variables defined in MapGuideViewerApi.js are not truly
unique. You can see this when you try to use the Redline widget, which
calls into the digitizing functions provided by this module.
Every time the widget digitizes a geometry, the MapGuideViewerApi module
will repeatedly add new OpenLayers.Layer.Vector and
OpenLayers.Control.DrawFeature objects to the map despite there being a
"global" boolean guard that is supposed to protect against this.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/569>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
