[fusion-trac] #626: KML/KMZ download from redline is useless when map CS is WGS84.PseudoMercator
Fusion
trac_fusion at osgeo.org
Tue Sep 23 02:13:16 PDT 2014
Reporter: zhanga | Owner: madair
Type: defect | Status: new
Priority: P3 | Milestone: 2.3
Component: Widgets | Version: 2.2 - RC1
Severity: Minor | Keywords:
External_id: | State: New
Browser: All | Os: All
Comment(by jng):
I think this is a bug in 2 areas:
1. MapGuide's KML renderer.
2. The default redline style settings for lines.
The line string geometry is there, but the style generated for it uses
line width of 0 (assuming no changes from the default redline style),
causing nothing to be drawn.
The default style uses a 0 line thickness. The default image-based
renderers in MapGuide seem to clamp 0 line thickness to some very small
value > 0 (which is why we still see such lines being rendered), but the
KML renderer does not and writes the thickness value as-is.
Workaround is to specify a non-zero line thickness as a default, proper
fix is to make the KML renderer follow the same behaviour as the image-
based renderers for dealing with 0 line thickness.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/626#comment:1>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
