[fusion-trac] #646: Overview Map Widget obscures Commercial Layer with GETMAPIMAGE as default
Fusion
trac_fusion at osgeo.org
Fri Apr 29 08:28:33 PDT 2016
Reporter: gluckett | Owner: madair
Type: defect | Status: new
Priority: P2 | Milestone: Future
Component: Widgets | Version: 2.0
Severity: Major | Keywords:
Browser: All | External ID:
Operating System: All | state: New
The Overview map blocks the underlying Commercial Map Layers (OSM,
Google,etc) with the Background map colour. This is because the Overview
map uses "SINGLE_TILE_PARAMS" and the GETMAPIMAGE.
If switched to GETDYNAMICMAPOVERLAYIMAGE the map then has the required
transparency.
Perhaps this should be the default for the OverviewMap widget.
Ticket URL: <http://trac.osgeo.org/fusion/ticket/646>
Fusion <http://trac.osgeo.org/fusion>
Fusion is a web-mapping application development framework for MapServer and MapGuide OS.
More information about the fusion-trac
